kerrton »
https://forums.nicoclub.com/kerrton-u88348.html
Wed Aug 10, 2011 10:31 am
It is much more normal with newer vehicles and I believe it is because of brake assist.
We just purchased a new Sorento and our salesman was very knowledgable, he demonstrated the brake assist functions to keep the vehicle level and prevent the nose dive when braking hard - this adds to the safety and stability of the vehicle when braking hard. The way this is accomplished is by the computer constantly monitoring brake pedal force and the angle of the vehicle, once you press firmly on the brakes and the nose starts to want to dive a little bit, the computer redistributes more brake force to the rear brakes and less on the front, keeping the vehicle level and in control.
The result of this system is increased wear on the rear pads and decreased wear on the fronts. If you drive very conservatively and brake gently you will see a more traditional wear pattern with fronts taking the brunt of the wear. If you brake a little more firmly, or are the type of driving who's "hard on the brakes", then you should see more rear pad wear, this is normal and by design, and does not indicate a bad rear caliper design. Of course there is always the possibility of sticking calipers, but rear pads wearing slightly faster than the fronts is not normally a cause to assume there are caliper problems.
