Rear Brake pads
Rockhoundrob
Car: 2009 Nissan Rogue SL
I need to replace the rear brake pads on my Daughter's 2009 Rogue.
The Chilton manual I have says the front and rear are the same steps... Remove one caliper bolt and flip the caliper and remove the pads. Then replace pads.
Is this really true? All the other cars I have worked on have either a emergency cable adjustment to do, or you have to screw the caliper piston in when replacing the rear pads.
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
It only gets complicated on gen2's that have the electric parking brake. The mechanical parking brake uses shoes inside the rotor hub, so you can do pads without ever touching them.
https://www.nissanpartsdeal.com/parts-l ... m=441_A001
Rockhoundrob
OH COOL !! great!!!
Thank you!
VStar650CL
Technical Expert
:dblthumb:
Return to “Rogue Forum”
