Hi all
I posted this in the EX 35 forum but I think these questions go here. I have a 2010ex35 with 40,000 miles or 60,000km. I just changed the rear pads and I have 3 questions.
1) The OEM pads had two shims, an inner shim and an outer shim cover. The Akebono Proact pads only have one shim that we can take off and smear anti-squeal grease in between it and the actual pad. I thought I had to use one of the OEM shims but the OEM shim and cover do not fit well on the Akebono pads (the Akebono have a little metallic "bump" on their back plate and the EOM shims do not fit on the pads flat because of this). Am I ok with only using the (one) shim that came with the Akebono pads? Should I discard the OEM shims?
Second question: the top slider bolt has a rubber end cap (on the bolt itself). Not sure why but I can't reinsert the bolt when the rubber cap is on it (I clean them well and reapplied grease). The other side bolt went it easily even with its rubber end cap. So right now I have the driver side without the rubber cap. Is there a trick to reinsert the slider bolt with its rubber cap?
Third: the bolts themselves seem to have some usage marks. How often do you guys changes your slider bolts? Is it necessary to change these bolts?
Thanks
