Meaux wrote:This is my first Post........
94 Q45 Stock, 78,000mi., 2nd owner. since 60,000mi. 4yrs.
After the car sits overnight, it feels like the rear brakes come on after about 10' of backing down the driveway. Is this some strange saftey feature? Sometimes I can pump the pedal and this sensation goes away. After that first morning "backup", everything seems normal.
While I'm thinking about it, what is the procedure for setting the TPS sensor. Seems like I have to press the accel. pedal down way to much for the trans. to down shift in traffic, taking a little slack out of the cable helped, or maybe the TPS is bad?
Love the car, just don't drive it that much.......
Thanks........
This is normal.. the ABS pump does its self test this way.. Completely normal..
The TPS is adjusted from the factory and as long as it isnt messed with it doesnt need adjustment... its designed not to have violent downshifts until you press it all the way.. So if your in 2nd gear going about 20 or so it wont shift into 1st until you give it gas all the way. Same is true for highway, it wont downshift to 2nd until you press it all the way...
I like this better, because with our GTP you press it a lot of the way and it downshifts... Very annoying.. There is a clicky thing at the end of the pedal (technical term being the kickdown switch) that activates this.....
