kepani »
https://forums.nicoclub.com/kepani-u22817.html
Mon Dec 06, 2004 9:54 pm
here's a quick run through for replacement of the rear brake pads for my 1996 240sx se. i noticed that the left rear brake constantly squealed. i finally figured that it would be the "low pad" metal indicator thingy (is there a better name for this?).
there's a big list of things that need to be fixed. however, i was fortunate enough to get this car from a friend who had to leave the country so i'm not complaining.
i headed over to the local nissan dealer to get a full set of pads (front and rear). turned out they didn't have the fronts in stock. i got the rears anyway since that was the source of the squealing. the set of rears cost me about $55.
tools: breaker bar torque wrench 14mm wrench hammer jack jackstands needlenose pliers brake wash
*unfortunately, my camera broke and would have definitely taken some pictures both for a record and for posting pics in a thread like this*
1) loosen lugs. previous mechanic who worked on the car did a full impact wrenching to the lugs. remember guys, always use a torque wrench! it should pretty loose when you break them.
2) jack up car.
3) remove lugs and wheel.
4) take your 14mm wrench and hammer. loosen the two 14mm bolts from the rear of the caliper. use the hammer to do the initial *break*.
5) push the caliper back and lift the assembly off of the disc. be careful not to rip the brake lines. they're pretty strong but just be careful.
6) pull out the old pads. be sure to either reuse the shims from the existing pads or use new ones. keep track of which shim came from which pad. large shim on outer, small shim on inner. also check how they're mated to the pads. sure enough, the metal squeal was due to worn pads! the indicator was flush to the pad surface.
7) install new pads. take a look at the new pads. the set i got had only one pad with the metal indicator. the one with the indicator goes on the right disc on the inside; metal indicator should be high, not low.
8) grab your trusty piston compressor to push the piston back in. or if you're like me without one (don't know i survived w/o one), grab a needlenose and turn the piston clockwise using the four indents. do it slowly as not to rip the piston boot.
9) lay the caliper back on the disc making sure it clears the new pads. you might have to go back and re-press or screw the piston further to get it in cleanly.
10) take the two 12mm bolts and tighten them back on.
11) remount your wheel and torque the 5 lugs (or 4 for the less fortunate ). per the manual, torque them between 72-87 ft-lbs. for the 5 lug pattern, torque them in a *star* pattern. for the 4 luggers, simply in a circle.
12) presto! no more squealing!
*just as a precautionary measure, please consult a certified technician if you are not sure how to do this yourself. i assume no responsibility for any incident that might have resulted from the information here.* :sigh:
hope the how-to was helpful! i might have missed some details but overall, you get the picture.
kepani
