eliterit wrote:... But usually when you do a brake job in the rear, since you push the piston of the caliper back in to give the beefier pads room, you have to pull the e-brake up so that the piston can tighten the pads onto the rotor.
What i think happened is that when I was pulling up the e-brake firmly a couple of times, i may have given too much force and the rotating piston tightened too much and now cant rotate back?????
is this possible or maybe the calipers are shot??
hmm, u mean after reassembly, u get in the car, step on the brake, then pull the parking brake handle?
that's possible, but did u take both caliper pins, clean, & relube them? take it apart again & try to turn the caliper piston to be sure it can turn... as well as de-glaze your pads/ rotors...
side note: i had a d/s seized up on me... rust on the piston & was hard to turn back in; effect was the brake pads was on the rotor all the time & started to overheat on that side. Nuthin like seeing smoke comin from the rear tire...
