Rear Brake Help Needed
notslow
Car: Nissan Sileighty
I am replacing my rear pads and I have already put the new pads in but am having the toughest time lining up the caliper with the socket for the upper pin bolt. In this pic (compliments positronone) is this socket supposed to have play like the lower one can push in? This one is completely stiff and there is no way, even if I put the bolt in first to be able to swing the caliper down.Oh, I have retracted the caliper piston as far back as it can go.Thanks in advance
-Kevin
martins_240sx
Car: 1990 240sx hatch, 1975 280z, 2005 F150 fx4
yes it should be exactly the same as the lower hole....try some wd-40
notslow
might need to get it replaced... WD40 and a hammer does nothing
martins_240sx
must be seized...sounds like 30 bucks at the junkyard...
navysnail
pull everything apart, remove the caliper bracket from the hub, remove the rotor from the caliper, see if that gets anything to let go so you can fix it.
positron1
Car: Project: 1993 Nissan 240SX Coupe SR
Daily: 2010 Honda Civic Coupe
So the piston is blocking you from swinging the caliper down all the way?
notslow
positron_ wrote:So the piston is blocking you from swinging the caliper down all the way?
yes, the length it is sitting at right now is too short for the pads. I can get the pad on but it will drag.
bikerskater
Car: 1990 240sx with s13 front end
so the piston is to far out? did you try and use needle nose pliers to push it back in?
