Rear brake conversion help
N2mesnob
Car: 95' SE Pathfinder
Ok I'm thinking of converting my rear drums to disk.I've been looking through the threads and must of them have been for the 240's and I'm not sure how universal they are for my application.One thread I found seemed like it would have me changing out the whole brake system.That plan also seems to be very costly and that does not appeal to me.I really only want to do what is necessary.I am looking for constructive and helpful information on this venture (i.e. parts I need, procedures to follow, things to look out for, issues that may, etc.).
SnowSurfLax
Car: 1999.5 Infiniti QX4
2006 Infiniti M35 Sport
Hasn't been done. AFAIK, can't be done easily.
I would look into the Z forum for hints. Not sure how it will affect some systems though, ABS, etc.
GL! Make sure you do a write up if you do it!
1BMFQX4
Car: 1998 QX4
Yes I to would like to do this Mod. I hope you get this done and it being a fairly easy swap! Good luck to you. Hope you have good news for all of us.
W O T
Car: 2001 Infiniti Qx4
EDIT ^^^^ your avatar is hot
What year is your pathfinder?
N2mesnob
Ok I've done more research and this is what I've found so far, check it out: http://nissannut.com/projects/H233b_disc_brakes/
