Rear brake caliper rebuild
elpiar
Car: 1992 KA-T
Anyone rebuild their rear brake caliper before?
AFAIK the piston is a screw type due to the mechanical parking brake mechanism. The front ones are easy. But these I don't know.
My question is, do you need to disassemble the whole caliper (which is a pain) or can your basically replace the piston seal once you twisted it out of the caliper housing?
ryan15
Car: 1990 240sx
elpiar wrote:Anyone rebuild their rear brake caliper before?
I replaced one of my seals, on my rear caliper, it was easy, just messy. I just replaced the piston seal and the dust boot, all really easy.
Ryan
elpiar
Car: 1992 KA-T
So what did you have to do to replace the seal, twist the piston out and that's it?
rob240sx
Car: 1990 240sx
does anyone have more input on this?
SINsanity702
Car: 1991 Nissan 240sx Hatchback LE 5spd (R.I.P.)
1998 Infiniti Q45
I've been doing brakes for 5 years, and I've NEVER rebuilt a ratcheting brake caliper. I simply hear that the labor is more expensive than a Remanufactured caliper...which isn't cheap either...However! I't's just brakes!, it can't possibly take that long to rebuild, ASSUMING you've done it before. Why do you need to rebuild it anyway? Those things never go bad....Unless they rust out, or they BROKE(seen it), which, u will need a new caliper anyway.
SINsanity702
1998 Infiniti Q45
Here are the directions from the FSM, but i cant provide the pics.....
1. Remove piston by turning it counterclockwise with suitable longnose pliers
2. Pry off Ring "A" from piston with suitable pliers and remove adjusting nut
3. Dissasemble cylinder body- Pry off rings "B" and "C" with pliers, then remove spring cover, spring and seat
4. Remove piston seal (be careful not to damage cylinder body
5. Remove return spring and lever
If u still wanna go through with it, lemme know, ill type up the install process. I can't copy it, so this took a while,
SINsanity702
1998 Infiniti Q45
o yea, and im guessing since u have to PRY off all those rings, u better make sure they come in the rebuild kit, cuz when i pry, i bend/break sh
scole
elpiar wrote:So what did you have to do to replace the seal, twist the piston out and that's it?
Yep, piston twists right out so you can replace the seal. That should be all you need to do besides the boot.
FWIW, i didn't fiddle with taking apart the piston like the FSM and previous poster say to do. I figured changing the seals would be all it needed.
