A lot depends on which head unit you're running. If you still have the Bose then no speaker is going to sound good unless it has it's own amp. If you've switched head units to aftermarket then you don't want to use a Bose speaker (bypassing the amp) since the ohm rating is low (1 or 2).
I'm not sure what system the 91 CTS has in it but if it's a Bose get the speaker and amp attached to it and it will bolt right in. The J30 6x9 Bose speaker is very nice (I have a pair in my Q45) so if it's just a pair of amps you're missing I have some nice ones here:
for-sale-bose-amps-for-q45-i30-j30-m30- ... 76914.html
