Yes please! I'll probably use my shop press, but if this is better, I'll look for one of these.Slappy wrote:Do you want me to take a pic of the C Clamp set i used?
Looks like you got the info you need. I was workin my *** off today so i didnt get a chance to take a pic of the clamp set.Dammitboy wrote:
Thanks for the part # Swinter!
Anyone know the part # for the front balljoints?
K
Modified by Dammitboy at 4:54 PM 6/16/2008
I used the c clamp looking Loan-A Tool from Auto Zone to both remove, and install the new ball joints. Worked great for the front and rear taking only a few minutes to remove and install.vancouverbc wrote:why do people say use a press when it is so easy to use a vice? as this video shows?
http://www.expertvillage.com/v...t.htm
would a c clamp work?
moog part #9820FlatBlackIan wrote:Just get front ball joints for the S14.
I just finished rebuilding my rear suspension, and I replaced the lower BJs while I was in there. I used Moog front BJs for an S14.
I checked the taper, and all other dimensions, and the new front, and old rears matched.
