Rear Backup Camera Display
ajab
Car: 2011 Infiniti M37x
When I shift into reverse my dashboard display flickers on and off. There's times where it'll work fine for an extended periods of time and there's periods of time where the screen goes black when I shift in reverse.
Has anyone else experienced this problem? If so how was it fixed?
Ilya
Welcome to the forum.
Might be a lose connection to the camera in the back? I would probably take off the trunk liner and see what's what.
ajab
Yes, I plan to do that soon. I thought I saw on a forum somewhere that there's a defect in the backup camera equipment so I was just trying to find that info again. That being said I'll start with looking at the connections first, thanks...
dmclone
Car: 2011 Infiniti M56x
I have the same issue. It a;ways happens after I close the trunk.
ajab
If it happens after closing the trunk maybe then it's a loose connection afterall? In my car it's intermittent and not associated with closing the trunk but it's worth checking the camera connection in the trunk, I'm going to check that soon.
