Auto or manual?
Manual, the switch is on the side of the trans, It's the first switch you come across moving back from the bellhousing.
Auto would have an issue with the inhibitor switch.
More than likely it's a fuse. The bottom right fuse in the interior panel is the one you need to look at. I've had that fuse pop before, killing my reverse lights.
