1964 L320, rear axle disassembly, bearing removal
I am not very satisfied with this post but I think it still has some usful stuff in it.
exerpt from the factory service manual found on the620.com courtesy of kenbagby of olddatsunpickuplovers.com:
From page 156 in the online document ( Fig. 14 is on page 158)
AXLE SHAFT REMOVAL
Jack up the axle on the blocks. Unscrew and remove the brake drum using a screw driver. If the brake linings should hold the drum when the hand brake is released, slack off the brake shoe adjuster a few notches. Take off the fix bolts of the brake disc and remove the axle shaft assembly as shown Fig. 14. Tap out with swing hummer holding wheel stud bolts with rear axle shaft. Draw out the shaft and disc assembly by gripping it outside of the brake disc.
Well the steps should be perfectly clear now. Having removed the bearing from the shaft you can remove the old grease seal and replace it. Wait, you look slightly confused, didn't the factory service manual describe everything clearly?
How unsporting of me, how american, poking fun at the technical engineer who transcribed the real directions into english way back in 1964 or earlier. After all, I will probably never speak or write japanese.
so here is the step by step as performed by me in my quest to replace my grease seals.
1. You must first disassemble the brakes, remove the drums, loosening the adjuster to get them off if you need to. Remove the springs, and remove the e-brake cable, you will need to pull the axle out of the rear end housing and the e-brake cable will stop you from doing this. the e-brake arm is attached to the rear facing brake shoe and it is clipped in and held by a spring, Maybe it is not necessary but i removed the brake shoe first so i could push back the spring and twist out the cable from the e-brake arm.
here are some photos that show the parts, the backing plate will still be mounted when you do these steps, I just took the pics to show the parts and how they fit together because i didn't take pics while i was doing the work.
[img]
http://i301.photobucket.com/albums/nn70 ... 0_2854.jpg[/img]
E-brake arm and cable with spring
[img]
http://i301.photobucket.com/albums/nn70 ... 0_2855.jpg[/img]
This shows how the cable goes through the backing plate
[img]
http://i301.photobucket.com/albums/nn70 ... 0_2856.jpg[/img]
This is how i got it off
[img]
http://i301.photobucket.com/albums/nn70 ... 0_2858.jpg[/img]
plus a little working in this manner. The cable was hard to get out of the plate, i was getting frustrated and had to remind my self to be patient!!
2. Once the brakes are removed then you can loosen the four nuts that hold on the bearing housing. The backing plate for the brakes will not come off of the axle, it is trapped by the bearing housing. After removing the nuts the axle was still tight on the rear end housing. The bolts have a tight fit through all the flanges , a light press fit. I used the nuts at the ends of the bolts and gently tapped with a small hammer to get them loose.Here are some pics.
[img]
http://i301.photobucket.com/albums/nn70 ... 2766-1.jpg[/img]
this is a pic of the axle pulled out, you can see the four bolts. See how the whole assembly comes out together.( That small ring you can see on the axle is supossed to be on the other side of the bearing, the last time someone worked on this axle they must have left it off when they pressed on the bearing and didn't want to redo it. I am glad they stuck it in there on the wrong side for me to find, intsead of tossing it out!!!!!!!!! )
[img]
http://i301.photobucket.com/albums/nn70 ... 0_2736.jpg[/img]
Another pic showing the greasy stuff. This was the first one i took apart.
3. Now that the axle is off you must remove the locknut, it has a locking plate and threads on to the axle. Look for the tab on the locking plate which is bent up and tap it down to clear the lock nut. Then use a screwdriver and gently tap the nut off, once loose it should turn by hand.
[img]
http://i301.photobucket.com/albums/nn70 ... 0_2734.jpg[/img]
Here is a picture, i think you can see the locknut and lockring
[img]
http://i301.photobucket.com/albums/nn70 ... 0_2894.jpg[/img]
[img]
http://i301.photobucket.com/albums/nn70 ... 0_2743.jpg[/img]
Here is the axle again with lockring removed, the bearing is pressed onto the shaft. In this pic i had set the backing plate on some 2x4's and tried to knock it out, no luck!!! This is the point i went and read the online manual and stared at it for a long time. Fig. 14 was the spark that ignited the flame. The "swing hummer" mentioned in the text was a "slide hammer". Well goly, I Have one of those. The text means that after you remove the assembly and take off the lock ring, put the axle back into the rear end housing, put the bolts back on. Then use a slide hammer which attaches to the lug nuts to pull the axle out of the bearing. here are the pics.
4. this step is in picture form
[img]
http://i301.photobucket.com/albums/nn70 ... 2747-1.jpg[/img]
The slide hammer
[img]
http://i301.photobucket.com/albums/nn70 ... 2757-1.jpg[/img]
Axle re-installed with slide hammer on lugs, a few good waps and.....
[img]
http://i301.photobucket.com/albums/nn70 ... 2758-1.jpg[/img]
TA DA!!!!!!! axleicus-removicus to quote the scientific jargon
Here is the front and back of the backing plate while off of the axle, before the bearing housing is removed
[img]
http://i301.photobucket.com/albums/nn70 ... 0_2769.jpg[/img][img]
http://i301.photobucket.com/albums/nn70 ... 0_2767.jpg[/img]
I removed the bearing housing by putting the nuts back on the studs and tapping them out with a small hammer, I saw it on a thread here about putting dics brakes on a 520 or 521.
5. now you can pop out the grease seal and check out the bearing and race, hope yours doesn't look like mine
[img]
http://i301.photobucket.com/albums/nn70 ... 0_2762.jpg[/img]
must of sat for a long time? the race is checked as well and the bearing looked worn as well.
6. To remove the bearing i welded a small piece of bar stock to it, fliped it over and tapped it with a hammer tell it fell out of the bearing housing
[img]
http://i301.photobucket.com/albums/nn70 ... 0_2860.jpg[/img]
Now that the whole thing is apart, I cleaned the bearing housing and made shure that there were no dings or scratches on the surfaces where the bearing race fits, everything looks good so I am ready to put everything back together,
Oh and I have to thank Tony, of T.n.T. fabrications, for lending me his slide hammer, I stopped into his shop to make a mounting plate for my slide hammer on his drill press and he just lent me his larger slide hammer with that nice lug mounting jig on it. Cool!!
