Rear Auto Roll Up Windows?
gibz4
My bosses car has the one touch auto roll up rear windows, mine doesn't. They are both 06 sport models. Is there something wrong with my car?
mjlyn
Car: 2006 M35 Black
I think something is wrong with your car. That is a standard feature. Your window switches have the letter "A" on them dont they?
cmbtrdy1975
Car: 2006 M45 Silverstone Metallic
This is from the manual.
If the windows do not close automatically If the power window automatic function (closing only) does not operate properly, perform the following procedure to initialize the power window system.
1. Push the ignition switch to the ON position.
2. Open the window more than halfway by operating the power window switch.
3. Pull the power window switch and hold it to close the window, and then hold the switch more than 3 seconds after the window is closed completely.
4. Release the power window switch. Operate the window by the automatic function to confirm the initialization is complete.
5. Perform steps 2 through 4 above for other windows.
If the power window automatic function does not operate properly after performing the procedure above, have your vehicle checked by an INFINITI dealer.
Poyzinous
Car: 2004 G35x Premium 1976 Classic Red 36 inch #18 Radio Flyer Wagon...
cmbtrdy1975 wrote:1. Push the ignition switch to the ON position.
+1
The windows may just need reinitialization.
gibz4
+1
Thanks,
I'll try it.
itsOmar
Car: 2007 M35X
Works like a charm on the front passenger on my 07 m35x
Fezzik
Car: 2010 G37 Vert w/ stage 1 GTM supercharger
Check and look on the drivers window switches. If it has an A on it then it has the auto feature. It may have lost the memory of the "up" if the battery was disconnected.
