Ceptos »
https://forums.nicoclub.com/ceptos-u840.html
Tue Aug 12, 2003 4:43 am
i could be wrong, but im under the impression that there is a different part for each type of alignment adjustment, and depending on what you wish to adjust, you must install the appropriate piece. for example, i believe rear camber is adjusted using an 'upper rear adjustable link', this being your only option for adjusting rear camber. front camber is adjusted using a camber plate. there is a fair amount of info in the FAQ section for suspension to get you started, google should solve the rest.
