Rear alignment off
A forum for the Nissan Quest... minivan lovers unite!
far raf
Car: 2005 Nissan Quest SE (standard? simple? edition - i.e. nothing special)
Was checking alignment with a string and found that the driver rear wheel is toed in by about 1/16".
Correct me if I am wrong, rear alignment is not adjustable? How can I fix the rear toe in then?
amc49
Car: '11 Nissan Versa
'17 Nissan Altima
The toe is usually adjustable.
Did you check the other side right, there may a light amount of toe-in on both sides to set the rear to front tracking in more firmly. I commonly do all my cars like that just a little, it makes them more surefooted.
I align all my stuff, they never see an aligning machine.
far raf
Affirmative: pass rear straight, driver rear toe in.
How would you align that? I don't mind a DIY, just want to be sure I know what I am doing.
God, I hate the splash guards getting in the way of a string at the axle height! But bending the guards in is not too hard, so the string test works fine in the end.
nissanquest95
Car: 1995 Nissan Quest
far raf wrote:
Thu Jun 29, 2017 9:28 am
Have you ever found out how to adjust the rear toe ins?
The manual doesn't say anything about rear alignment. I wonder if you need to replace the rear axle or wheel hub.
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
Beam axles like your '95 never have adjustable toe and camber, you'd need to bend the axle. See RA-4 and RA-16 here:
https://www.nicoclub.com/service-manual ... 5%2Fra.pdf
There are specs, but the inspection procedure basically says, "If it's out, replace what's broken."
Return to “Quest Forum”
