reamanufatured head
Master_Tao
Car: 93 skyline gts-4
ok, so I was just browsing automotive machine & supply and they have a ca18de remanufactured head for a 87 pulsar I was just wondering if it would work on my ca18det?
Master_Tao
maybey this will help a little more http://www.automotivemachine.com/204.htm
biosehnsucht
Thats who I had bore and balance my bottom end.. (built it myself)
Hrm, that says ca18 and ca16, so I'm not sure hwich it is...
if its a FWD CA18DE head it should be interchangable, although you'll have to swap parts from existing RWD stuffs (unless you have a FWD) i.e. the EGR **** (look at left side of the head image).. if CA16DE not interchangable
Not_a_sr
Car: 90 ca18 pwrd 240sx FB
Master_Tao wrote:ok, so I was just browsing automotive machine & supply and they have a ca18de remanufactured head for a 87 pulsar I was just wondering if it would work on my ca18det?
whats wrong with your head?
float_6969
Remember that the USDM heads have a port in the #4 exhaust port for EGR whereas the JDM head's don't.
biosehnsucht
like I said. but if he has the old one he can swap it over
NeedCAforS13
Car: CA swapped S13 coupe
float_6969 wrote:Remember that the USDM heads have a port in the #4 exhaust port for EGR whereas the JDM head's don't.
nah, upon closer inspection they're the same... if you have a JDM head to pull that plug from you'll be fine. your JDM head has the hole for the EGR just like the pulsar on the #4 runner it just has a plug!
Sean
Master_Tao
Not_a_sr wrote:whats wrong with your head?
nothing that I know of, I was just going to get one to be safe but I've been convinced by a friend that it's not necessary. I do need to know however what I should be checking for problems. I've also read about solid lifter upgrades. What are those all about? and one more question. what other head upgrades are availible for the ca18det?
redamnavit
Master_Tao wrote: nothing that I know of, I was just going to get one to be safe but I've been convinced by a friend that it's not necessary. I do need to know however what I should be checking for problems. I've also read about solid lifter upgrades. What are those all about? and one more question. what other head upgrades are availible for the ca18det?
Unless you've noticed something wrong its likely the only thing in your head that should need replacing is the spark plugs. As for solid lifters, they'd be the last "upgrade" you'd be considering, really only applicable for a 9K RPM race motor. They're noisy and need regular adjustment. You'd have tossed a fair amount of money at high lift cams and stiffer springs before they came into play.
Does your car run yet?
Master_Tao
thanks for the info. I've been wondering just that for a while now. And sadly enough the engine does not run yet. I'm still about a month away from that.
TheSnail
Car: RB26 powered 93 s13
I have a great condition ca18det head I will sell for 100$
