480sx »
https://forums.nicoclub.com/480sx-u50548.html
Wed Jan 16, 2008 6:06 pm
Dont listen to these guys, useless.
Im not sure how big the sidemount IC is for the 300zx, but the place your talking about putting it is the normal spot for a sidemount. Right underneath the flat spot in front of the wheel well right? Thats where it needs to go.
I guess you have a 300zx sidemount already? IMO, i would sell it and get a sr20det sidemount. Well before you do, research it and figure out the size difference between the two. The SR ones are cheap, and fit correctly with little modification. If you already have a 300zx unit, just go outside and try to figure out if it will fit under your wheel well.
Your idea about using the cold air intake MIGHT work if its a aluminum tube type of one. You would need to buy a generic intercooler piping kit from ebay or something, along with some silicone and clamps to make that work. You wont need to drill any holes under the headlights, the fender area receives plenty of air.
Btw, are you running an SR, Ka-T, how you boostin man! Good luck with your project, and dont let flack from these kids bother you.
