unichi »
https://forums.nicoclub.com/unichi-u29586.html
Wed Apr 05, 2006 1:11 pm
I think it depends on what your tire size is. I'm just guessing here, so if someone can correct me, please do. The angle can just be represented by a triangle that has the overall tire diameter as the hypoteneus. The side opposite the angle is half the 1/8" toe setting. If you take the inverse sine of opposite/hypoteneus you get the angle. For my tires, which have a diameter of about 23.9" the angle would be about 0.15 degrees.
Now, this is assuming that you're talking about a toe setting that is 1/8" difference between the center of the front of the tires to the center of the back of the tires.
I have a bad feeling like that whole thing made absolutely no sense.
