Really need some help on this one
BreatheLife21
Car: 96 zenki soon to be zouki
I swaped a ka24de out of a wrecked 240 into my new s14 did everything with the 5 speed swap and i cant get the engine to start. Fuel pump isnt turning on when i turn the key on at all just got a new ecu today and it didnt fix the problem and i checked the power going to and from the ecu fuse panel and the relays
any ideas i really need to get this car running
ohvictor
Car: 240sx & G35
BreatheLife21 wrote:I swaped a ka24de out of a wrecked 240 into my new s14 did everything with the 5 speed swap and i cant get the engine to start. Fuel pump isnt turning on when i turn the key on at all just got a new ecu today and it didnt fix the problem and i checked the power going to and from the ecu fuse panel and the relays
was the motor good from the 240 u pulled it from?
i would disconnect the plug on top of the fuel pump in the trunk and turn the key on then check for power going to the plug if u got power there then i would either use a fuel pressure gauge to make sure its pumping or just disconnect the fuel line before the fuel rail put the hose into a empty plastic bottle and turn the key to see if gas is flowing.if u dont got power then u should recheck ur fuse and relay if u do got power and u dont got flow its more likely ur pump
also check for spark
BreatheLife21
yea the motor was good only had 43k on it and checked everything u listed except spark.
the motor came out of my 240 i wrecked
nrmskate
Car: 89 Nissan 240SX
Check the voltage running through the Ignitor, and just out of curiousity, stock fuel pump and injectors?
BreatheLife21
yea everything is stock about to go rule out some more possibilities now
