waggs »
https://forums.nicoclub.com/waggs-u19756.html
Wed Sep 15, 2004 12:35 pm
Let's see if I can explain this correctly...my Ininity J30 will not start because apparently the computer won't go into "on" mode.
For about the last year, if I tried to turn the key too fast, the car would either start and die right away, or wouldn't start at all. I could usually get it to start by making numerous attempts. It took me awhile, but I finally figured out that during the times that it wouldn't start, it wasn't even running the warning light's on "diagnostic" that every car does when you switch it to ON mode before cranking the starter.
I solved this problem for about a year by alwasy waiting a few seconds in ON mode before cranking the engine, but now even that has stopped working, and the car won't start. It's weird, cause the radio and the air will still turn on, but the dash is completely dead, and it won't even try to start. If the car actually does run through the diagnostic, however, the car will start with no difficutly. Does this make sense? Does anyone know what this is?
