ejXa q45 »
https://forums.nicoclub.com/ejxa-q45-u34266.html
Sat Nov 18, 2006 3:10 pm
i have a really bad idle and i cant seem to fix it ........... first things first i have a 92 q45 with around 120K .
i was driving home from a Friends house .when i got in my car and started it ........it stalled out, most likely because of the acc was to set to low. it was raining and the roads where wet so i drive up this hill and there a puddle that i could not move in time to miss os i went right into it. now my car is driving a little funny i get home and go to work the next morning and my car has a bad idle worse then it ever had before .......... and i know a bad idle when i feel one because my Q all way had a bad idle ..... but now its worse . when i drive its like driving with 2 out of 8 cylinders until i get to about 2800 - 3000 rpms not to sure no that but any ways i disconnected the battery for about 10 minutes and nothing........ so cheeked ecu for codes i got a bunch but this could be because i was pulling wires to try to fix the problem but i know i got a 21 and 13 ....... next i reset the ecu and started the car w/ out the ecu fuse and ran for 2 seconds whit out a problem......long story short i think the ingnitor chips or Ignition Module (the thing on both valve covers) are bad because the car runs like there unplugged ..... i know what this is like because i did it once before when i put my transmission it because the wire where in my way and i forgot to plug them in but this is different because when they where not plugged in the cars rpms would not go over 2000 at all. and now the car will run fine if above 2500 - 3000 it kind of funny the car will move so slow and then bang ........... it at red line in milliseconds .... i have no clue just like always on how to fix this or for that matter what this is .......
i looked this up and posted something but the post was old i think
help me q45tech, wes anybody
