Best advice You are not limited to the dealer you bought the thing from.Andrews Chalmers wrote:find a new dealer.
I get 10/100 in the city and around 9 on highway.frankoV wrote:Best advice You are not limited to the dealer you bought the thing from.
Also, be aware that the CDN government hasn't change dthe mileage ratings even though real life driving shows much differntly than sticker.
9 and 7 l/100 km are about decent -- unfortunately.
oh, and as Andrew says . . . 5,000 RPMs is much much too high
See that is where the issue lies, B.C is mountainous(if there is such a word) very hilly so it hardly ever maintains the same revs.Andrews Chalmers wrote:On a level surface at 60km/h, my Versa CVT will often maintain that at less than 2000 rpm.
My area is, too, but I NEVER see it go above 4000rpm. I can maintain 65mph up a steep grade at 3500rpm, and usually keep it at 2000-3000rpm depending on the speed limit and slope. You do have a problem if you're seeing 5000rpm and don't have the OD off.NODES wrote:See that is where the issue lies, B.C is mountainous
Tire pressure would not cause gas mileage to be that horrible.7speed wrote:I would also check your tire pressure. It's just another one of those simple things that get overlooked sometimes.
