ka-J »
https://forums.nicoclub.com/ka-j-u9084.html
Sat Aug 23, 2003 11:21 am
check your main ground wires, There is one from the battery to the chassis, & then one from the chassis to the engine. Make sure you have a ground from the engine to the chassis, & check for corrision that could prevent the ground from flowing properly, generaly when you turn your lights on and have a problem, it means the grounding system is not flowing properly. There are many other ground wires that come from the wiring harness to different spots on the engine and chassis, It would'nt hurt to clean them. good luck. If that does'nt work than post up again with more info about your problem.
