raging panda wrote:if you cant replace clutches, how are you getting all this horsepower? If you cant afford to replace things that wear out on a drift car, then you shouldn't be drifting. That is the truth. I have spent a lot of money replacing things, pretty soon the clutch is one of those things. Your power goal isn't realistic, because if you have enough power to do a burnout from a rolling start in second gear, your tires should have enough grip to not spin but harness that power to the ground. That means more money for bigger tires, and probably bigger wheels. To start drifting, you should learning techniques and ways to overcome your lack of power, not finding ways to make drifting "easy" because even then it won't be. But if you can't afford to fix things that break from drifting, you shouldn't be drifting.
And stop bashing hondas, they are cool, its the people that are stupid.
i agree with you,
if you are ganna drift, expect to change things alot, like tires, clutchs, sometimes suspention stuff, engine stuff, much more things, i dont know how you wanna drift and not change wored out things that have to be replaced. and nobody is arguing with you, you ask a wierd ?, and we try to answer it . heres my last answer
you can spin your tires on a stock a$$ 240, and as for you drifting, IMO, this sport is not for you,cuz you say you don't wanna change clutches and any other parts, so just don't drift, and even for anyother thing you wanna do, if you drag race, need better parts, autoX , need better parts, so you still have to change parts no matter wat,
