realistic, practical vented hood
Fenvy
Car: 2005 350Z Base 6MT
hi! it seems like one of the best way to vent the heat from a turbo manifold is to have a vent right above/near it... I probably don't want to buy a hood but rather, cut a hole and put grills on it.
that's sounds like something stupid to say but just wondering if anything has done something like this?
I said pratical/realistic because rain/dust/dirt/prankers will have to be considered just wondering if anything has anything positive to show me?
214kka-et240sx
Car: nissan s13 silvia
well,i think the best and easy way, and that works really good and cheap, is to put spacers into the hood hinches were it bolts to the hood, and alot of ppl have done this, and it lowers the temp by alot, so maybe this might be better. but maybe your idea might work too,
onosqv
Car: '92 240sx Vert
I know there was a guy on here who's cut a hole in his hood for the turbo or side mount intercooler (made it the "o" in his nismo logo on teh hood, haha).
You just need to make some sort of protection for it for when it does rain (I think he had a problem w/ this too). Being in socal, you should be ok for a few months, haha.
Or, you could mold an ebay scoop on top & make a hole there.
It would be unique points, but actual gains are questionable... keep in mind this will also mess w/ the airflow/aerodynamics of your car since there is now another flow/resistance path(neglibly, but so is adding the hole, so maybe it all just cancels out).
Badfish
Car: 93 Nissan 240SX w/ black top SR20
that was rudee023's car. Here's the thread.
zerothread?id=85947
Dunno how it worked. You'd have to ask him.
raging panda
Car: s13 coupe
if you are all about DIY, you can do a drop vent
http://www.hachiroku.net/mod/d....html
done on a corolla, can do it on your 240 also. I think im going to end up doing it since my car overheats a little when i drift for a while. I have the hood spacers too and I don't know if it works or not but it looks pretty cool. Eventually im going to buy the uras vent and rivet it to my hood and just cut a huge hole in the middle of the hood.
themadscientist
just run without a hood. I did that once, I was wrapping up a header swap and needed some lunch so we rolled out with the DE in the wind. Temps were real cool and the weird looks were fun.
Fenvy
themadscientist wrote:just run without a hood. I did that once, I was wrapping up a header swap and needed some lunch so we rolled out with the DE in the wind. Temps were real cool and the weird looks were fun.
gulp* that's asking for trouble.... I htink the hid, z32 maf, pipings will be the first to disappear
I do like rudee's idea though
Florida240sx
I wa sthinkign of just cutting a hoel than using some of the galv medal mak emy own miniature scoop....I got fiberglass....Kinda be like the dsm's bump except with a hole in front.....
nismo521
Car: 1993 Nissan 240SX HB
Doesn't raising the rear of the hood cause a safety problem though? The hinges would be over the top of the stops that keep the hood from moving rearward in an accident. One of the guys on a Nissan truck forum that I frequented when I had my pickup turboed his KA and molded the scoop from a Z31 into his hood. Worked pretty good.
D Money
Car: driving illegaly
i was planning on doing the sme thing, i would cut a rectangular hole in the driver side corner, with a little edge sticking up in the front. right over clutch mc. water+red hot turbo=expensive problem
574-240sx
Car: Nissans, Toyotas, Subaru
We so did that the first week I got my turbo kit on.
Juujai
here http://www.240sx.org/links/installs/hood/hood.htm
of course you can customize how you want it and everything so it's all on you. you can basically copy any design, evo style, msports, re amemiya hood, whatever oh yeah that gay looking invader hood haha.
Bronze MFP
Car: 1987 Nissan 300ZX w/digital dash radness
Turbo magazine's project supra had a CF vented hood that they cut more channels in near the turbo, dropped the under hood temps quite a bit, somewhere in the 20 degree rang if i remember right.
hannibal
Car: Red Line to Glenmont
Juujai wrote:here http://www.240sx.org/links/installs/hood/hood.htm
Thats the link I was trying to find. I like the vent better than a scoop.
I never thought about the safety issue with putting spacers under the hinges. ..
dfw240_EE
Car: 1992 240SX
I suggest using a pick axe to make speed holes in your hood like Homer Simpson.
Ok, now that is off my chest, isn't the fundamental idea that as you go faster a low pressure area develops over the hood, and that low pressure area sucks air out of the engine bay?
