Yeah I have seen the video over 1000 times im sure...lol. When are you seeing full boost? My only concern is when I will see full boost with the rb25. I believe you are taching your rb26 up to like 8500 correct? And how much boost are u running again?Booztd 3 wrote:My power numbers are pretty well documented with this turbo (essentially)
Mine is not a bullseye S366 but it is a Borg-Warner 91/79 (the official name)
On E85, 1000cc injectors, mild cams, full-race manifold with twin 44's, stock ignition, AEM EMS and an otherwise stock RB26(never touched the bottom end) I made 718rwhp/586rwtq on a mustang dyno. I dont get too caught up in the numbers but that would have been around 800rwhp on a dynojet. FWIW I've trapped nearly 140mph in a 3600lb car with this turbo. At this point my only limiting factor is the fuel injectors. On the dyno we were at 90+% Duty Cycles
Boost was tapering off, speculation can only formulate it was caused by the manual boost controller I'm still running to this day. Would like to get a GM boost solenoid and tie it in to the AEM but i have been so distracted. Also I've noticed the loading of the dyno seems to dictate the boost as well. On a 1/4 mile pass I see the boost pretty rock solid at 25psiRRRRB wrote:was the boost falling in that graph? i was looking and saw its says 24-28psi or something of the sort...
Reguardless thats great power for stock block.
I just bought a 6766 billet precision T4 1.00 divided turbo and some 260 10.25 cams in hopes of simular numbers on my Rb25/26 combo im working on hopefully i will have it done in a couple months, waiting on the head....
Have you ever weighted your car Andy? I'd bet that has something to do with more breakage... Whats ur best 60' to date?Booztd 3 wrote:The only issues I've had are drivetrain issues after repetitive beatings at the track
http://www.youtube.com/watch?v=5fwqPIc-yt4
I'll go through a trans a year usually because of those stupid synchros starting to grind but I never fix them - I just buy another used transmission and go about my business. A few times I have also broken the shift fork, but I think I was just being over abusive on it.RRRRB wrote:you break anything in the trans?
I'd make sure you check hood clearance firstly. Also keep in mind you need a non divided manifold. It works and is worth the price with a large turbo on a small displacement motor.meet07 wrote:
I was looking at the spool valve that sp makes....whats your guys take on it? Little pricey but seems to be a great add on for the price....
http://www.youtube.com/watch?v=I6ZCOTFET6s
http://www.youtube.com/watch?v=_KNLKVgg ... re=related
Shocker wrote:I'd make sure you check hood clearance firstly. Also keep in mind you need a non divided manifold. It works and is worth the price with a large turbo on a small displacement motor.meet07 wrote:
