realistic boost on stock injectors and maf w/ toyata ct26?
95hondakillr
Car: 240s
Have searched this but being a different turbo I figured I would ask. How much boost can I run with stock injectors and maf while running a toyota ct26 turbo? Any info will help, so far this site has helped me in every dilema i've come across and I just want to thank everybody while im at it for sticking together and helping each other out. I know a few people have ran this turbo so this ones for your brain teaser. My setup is a toyota ct26 turbo, log style mani, stock internals, apexi s-afc 2, high volume oil pump, apexi boost controller, walboro 255lph fuel pump, and thats it so far. Any help or comments appreciated!
Checkered-Member
Car: 1998 Nissan Altima (modded)
2003 Audi A6 2.7T (stock)
there is a guy on here running 5psi on stock injectors that would pretty much be the limit
hannibal
Car: Red Line to Glenmont
Ive heard 4-5 psi on stock injectors. Your fuel pump may allow to reach 5 psi. Just make sure it isnt leaning out.Consider used 370cc injectors from a SR or VG. Only about $100
WAbernethy
If you already have the AFC then you should def. kick in the extra $$ for some new injectors. I've got about the same setup with bigger injectors and I've been running 9psi on stock internals.
95hondakillr
Car: 240s
I know this is going to sound stupid to some people but I was flipping through the afc manual and was wondering what type of car do you program it to? Im going to have someone program my afc but i was just curious what car to select since they are all j-spec cars listed. Thanks for the replies I will be getting bigger injectors and a 300zx maf I want to realiaby run up to but not all the time about 11 lbs. I know i will probally need 50lb injectors for this though as well as all the top feed crap. Im going to read the afc manual and if its not that complicated I will program it myself I just dont want tom screw anything up, but on the same token I will know how to adjust stuff if i do it and i dont want my car being a "mechanics car" because i have no clue how to do anything to it.
95hondakillr
Car: 240s
BTW WAbernthy have you had your car dynoed?
huguetpj
Car: 93 KAT Coupe
Just set it to MAF, 4 cyl, Throttle up. Am I forgetting anything?
huguetpj
Car: 93 KAT Coupe
Now I remember, Karman doesn't use sensor number nor sensor cal, hotwire does.
So to set it up, and per the instructions on http://www.apexi-usa.com/documentation.asp
1. Set Sensor type to Hotwire2. For both S13 & S14 stock MAFs use sensor no. 5 in & 5 out (use 2 in for Z32 MAF)3. Set sensor cal to 1 in & 1 out4. Num of cylinders to 4 (in some cars it needs to be set to 2 due to the ignition config, I don't know if this is the case with the 240)5. Set throttle to up
Now I believe I ain't forgetting anything.
WAbernethy
Yeah, had mine dynoed back when I first finished my initial setup. Was getting something like 160rwhp/180tq at 5psi. I got bored with that pretty quickly and changed the boost to closer to 9psi. The old program seems to work fine at 9psi as well. I will be going back after my rebuild and all the other little "fixes" are done. I'm going to have a 10 psi program and maybe a 15 psi program. We'll see.
HIGHLIFE1
runing 6 psi on stock injectors, got a SAFC 2 as well, i think the stock injectors can get up to 7 psi not sure though
J
ftrs13
Car: KATs
so would I be running extremely rich at 5-7psi with an 8:1 FMU??
