Nismo300zx wrote:you can tell by many things...usually yes the hicas missing is ideal but u can tell by the psi meter marking the turbo boost.... the sport and touring button..the list can continue... but yea go with the hicas check up
Also, a swapped TT will cruise at about 3500 RPMs in 5th gear at 85mph due to the ratio of the N/A diff.
NolimitZ32 wrote:http://www.300zx-twinturbo.com...al=25
That is for the Euro Z32's. USDM Z's and pretty much all other Z's codes up to Z32 can be found Here.
VIN is the ONLY difinitive way to tell.
