Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Fri Apr 14, 2006 5:05 am
you can put a spark plug wire in there, but I have found that the inductive timing loop (black wire that protrudes off the harness behind coil pack #4) works just as well and requires less time and effort to set up.
Personally it sounds like it's related to the CAS. Reinstall it and see if it fixes it. Or if that doesn't fix the issue, borrow a friend's. If your friend's works right, then you should replace the CAS
