real quick ka24e-de questions
funigui
Car: I HAD a 1991 240sx coupe. woked NA motor. ran like 14.5 ish. blew it up @ 140 after an ECU reflash.
ive read hitmans article on doing this just a few questions
I have a harness and ecu out of a 92, my car is a 90I have a s14 motor
I know i have to use the s13 dizzy and ignition coil and ignightor chip.If i put the s14 intake mani on the motor, will the s13 harness connect right too it?
if so next sunday ill have a dohc
speeds8r
Car: 1989 240 hatch / 1991 240 coupe w/96 motor 70k
I think you'll have to use the intake of the 92 as some of the emmissions electrical connectors are different etc.When I swapped mine I had to , or rather did to make it easier at the time
Import_Ant
