Real or Fake ?
Your stop for everything on Nissan's performance brand. Whether you're looking for info on the new Sentra NISMO concept, the GT-R NISMO, 370Z NISMO, or just some of the many NISMO branded parts - You're in the right place.
Brisak
Car: 2011 Infiniti M56 S
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
As stated previously the NISMO tag is FAKE. The details etched on it appear to be correct, but it's still bogus.
2011 INFINITI M Press Kit
Welcome to VIN Decoding :: provided by vPIC
Brisak
Thanks I never posted those ones,Why would someone fake a badge in the engine compartment seems silly
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
That would be a great deal of trouble for a car that sold to you for bottom dollars. I'm going to run the VIN at the shop on Tuesday, maybe it was some kind of technology demonstrator or sales tool. If so, it will show a late in-service date and probably a lot of miles before the ISD. That's common with special-purpose stuff because the VIN's don't enter the system till corporate is done with them.
Brisak
VStar650CL wrote:
Sat Jan 30, 2021 6:31 pm
I was thinking the same think help for the info It seems silly to fake something you or a mechanic will ever see.
It just indicates there was maintenance performed on this engine at some point by Omori.
Could be as simple as a Fuga owner getting an oil change.
Production date for that engine is 6/2010.
VStar650CL
Technical Expert
I still don't get it, AZ. It's listed as a US emissions package. Something is weird.
Yeah, agreed. Is that placard on the car you bought, or is it on the front clip of half-cut (imported takeout engine)?
If it's on the car you bought, I suppose the car could have made it to Japan and back (military officer?) but that's highly, highly unlikely.
Brisak
AZhitman wrote:
Sat Jan 30, 2021 10:53 pm
AZhitman This is the same car.the one the guy sold me for 3400 that he said ran but had engine problems.He swore to
It ran and had a bottom end noise.But then some joker came
And tried to jump start it and blew the fuse out the fuseable
Link holder.They tried to rig it back together poorly with the right side fuse missing and used a washer to bridge the connection.
They never started it again and decided the engine gave out.
The car just clicks when you turn it over and message on screen says warning key system and rapidly clicks.It does not sound like the engine is locked i think you would hear a awful stater sound it that was the case
Brisak
[youtube]Image[/youtube]
Brisak wrote:
Sat Jan 30, 2021 4:53 pm
Gotcha. Any number of components could have been fried if a jumper was connected wrong. VStar probably can give you the walkthrough.
Brisak
Does this sound like totally locked engine the shop its at haven't even taken a wrench to it yet. I screwed with it for an hour all system key up.It has literally ever option ever invented ar the time .
Brisak
Brisak wrote:
Sun Jan 31, 2021 12:18 am
Fuse missing post bonded poorly together with washer
Brisak
VStar650CL
Technical Expert
If you're getting a bunch of rapid clicks then it probably isn't locked up, that sounds more like high resistance somewhere. Usually a locked crank will give you one solid "thunk" but nothing moves. Try spinning the crank with a cheater bar, that will tell you if she's locked. If not, you'll need to do some old-school voltage drop diag for the starter circuit, because the starter location on VK's makes tripping the solenoid manually to test it impossible.
Brisak
Thanks Vstar I think its because of that rig job they did on the battery fuse terminal.In the pics above where I circled
In yellow the entire section is missing and they bonded the two posts with a washer
VStar650CL
Technical Expert
The whole thing could be cracked internally, that isn't unusual when people mistreat them. But with an unknown issue on an unknown vehicle, a spin with a cheater bar will save you a lot of electrical tail-chasing if it turns out to have a bent rod or seized bearing. If the starter is fused, then a locked motor will pop that fuse.
Brisak
Thanks VStar very helpful,I want to bring this baby back from death
VStar650CL
Technical Expert
Well, it definitely wasn't a corporate car. Service record shows it sold from Clear Lake Infiniti in Houston with 3 miles on the odo. It received very regular service for the first 44K at Coulter Infiniti in Mesa, AZ. Then there's a gap to 64K, where N/I apparently slapped it with a branded title and a stop sale. The latter means no N/I dealer can legally sell it without an explicit release from corporate. My guess is that it was sold and the 2nd owner blew it up, then tried to make a drivetrain claim which N/I rejected for abuse. There's nothing after that, and it's anyone's guess about the Nismo plates. Coulter is apparently a high-end dealership, you might want to check with them and see if they know anything.
Brisak
Thanks vstar Engine is toast went wor the 12k Long block straight from infiniti
Return to “NISMO”
