float_6969 »
https://forums.nicoclub.com/float-6969-u780.html
Mon Dec 18, 2006 2:57 pm
Anything more rich than about 12:1 is wasting gas. You can run more timing by running more rich than that, but the motor is less effecient that way.
Here is how I tune; Since you're using a SAFC, set the base timing to 10°BTDC. Then get the AFR mostly even across the board (ie; 11.5:1 from 3K-Redline). I don't know if there is a way to do this, but with the SDS there is a general lean/rich knob that will add a certain percentage to the basic injector duty cycle. This allows you to add or remove fuel from the entire fuel curve. Starting at 11.5:1, lean the mixture until you make peak HP or start to detonate. Don't go any more lean than 13:1 (it's unlikely you'll still be gaining HP by going that lean, but just incase). From my experience, you'll end up around 12.5:1 as your peak HP. Once you get the peak HP fuel worked out, start adding timing back in via the CAS that you retarded back to 10° earlier. Do it in 2° increments. When you audibly hear knock, back out of the throttle immediatly, and then pull the timing back 3°. Don't go past 15° base timing.
That should make for a powerful, effecient, and safe street tune.
