So lets catch things up to date.
I got my Head completely clean. I got the gasket rebuild kit from cometic gaskets.
So first was first. I got the valve seals in. I used a 10mm socket and 1/4" extension pressed each one to fit snug. Then I placed all the valve spring sheets, put the valves through the guides, then the springs, retainers, and the last and best part Getting those damn keepers in. Personally I dipped a flat head screw driver in assembly goo then placed the keeper on there and in they all went about an hour or so later. So now my valve train is pretty much finished.
Im still waiting on my block. A sleeve was going to be fitted to correct the scratch from the wrist pin.
So ill be getting new forged pistons from cp and continue to use my stock rods.
I got clevite main and rod bearings just waiting for this block to get back.
So far im making progress.
once I get this block back ill start throwing up some pictures.
