That all sounds good.Dont forget those pesky resistors for the injectors.As far as the mafs goes, here's a brand new cobra mafs for sale real cheap compared to JWT pricing:freshalloy cobra mafs linkrn240sx wrote:Ok guys, ive been at 7 psi for the longest time and im ready for some more boost...I just wana be sure that I get the right brands and parts here.MSD 72lb injectors (have to send off my ecu for re-prog)96 300zx MAFWalbro 255 LPH fuel pumpJWT fuel railNISMO adj fuel pressure regulator (to lean up the ultra rich jwt setup)
Does anyone have any bad issues or experiences with the above brands..?? Am i missing anything..??Any places where u think i can get them for a descent price..??
ThanksRobert98 240sx ka-t
You can lower the fuel pressure above or below as long as you have only an adjustable fuel pressure regulator. If you use a universal fpr on top of a stock fpr, you can only raise pressure above stock fuel pressure(43.5 psi idle with vacuum hose disconnected).A stock fuel pressure regulator and a nismo fpr are both 1:1 ratio.Basically if you boost 10 psi, your fuel pressure should be 53.5 psi.If you boost 5 psi, your fuel pressure should be 48.5 psi. This is all assuming that the stock fpr or adj. fpr is set or rated at 43.5 psi at idle...etc.Typcially with Jim Wolf setups, their programming tends to be rich so you can lean out your air fuel ratios by dropping the base fuel pressure but you have to realize that it will affect the whole air fuel ratio curve typically. Some people have gotten away by leaning out Jim Wolf programs with adj. fpr but it might be better to use a S-AFC to trim at certain rpm points.Jim Wolf fuel rails have the location for use of stock fpr. So either you have to run a Nismo fpr that will bolt into the same location or you have to cap off with a plate and run a universal adj. fpr at the end of the fuel rail. Jim Wolf gives u the option and JGY will do either or.MarkEmark wrote:About that nismo adjustable FPR---You said you want to use it to lean out the JWT setup. I think mine's rather rich right now too...Can the nismo fpr lower the fuel pressure BELOW what the stock pressure is to lean out the a/f, and how much? And how much would lowering the fuel pressure translate into @ the injectors? Is there some formulal for the flow @ a certain pressure? I guess you'd need to dyno it with a/f charts to really see how lean you can get from lowering the fuel pressure. Sorry for the hijack, but I may add a nismo fpr sometime....
