sparkplugs.com »
https://forums.nicoclub.com/sparkplugs-com-u23266.html
Mon Jun 06, 2005 9:38 am
Looks like you may have had deposits starting to build up. Its kind of borderline, an overheated plug has the white deposits & dark speckled deposits on the ceramic tip. That could cause overheating, which will lead to pre-ignition, the plug electrodes melting & damage to the piston.
Here are some causes of overheating:
Ignition timing too far advanced, air/fuel mixture too lean, insufficient cooling water & lubricants, applied turbo boost pressure too high(in the case of a turbo engine), insufficient tightening of the spark plug, use of too hot a spark plug.
You might be ok for now, id just keep an eye on the plugs, and if you start to see the dark speckled deposits too, then you'll know theres something else going on.
