TomNJ »
https://forums.nicoclub.com/tomnj-u96381.html
Thu Mar 01, 2012 3:48 pm
I just checked the transmission fluid level on my 2008 Nissan Altima CVT and find the reading confusing.
The dipstick has two notches on one edge, which I would normally associate with the high and low fluid levels, but it also has a cross-hatch box on one side which does not line up with the notches. The length of the cross-hatch box is the same as the distance between the two notches, only off-set. The box starts about 1/4" above the top notch and ends half way between the two notches.
My fluid reads just below the top notch, but at the bottom of the cross-hatch box. There are no words on the dipstick to help, like "add" or "low" or "full", and the owner's manual is no help either.
How should I interpret this reading - should I use the notches or the cross-hatch box?
Tom NJ
