READ CODES!???!
jynjos13coupe
Car: 1992 Nissan 240SX SE Coupe
Is there a computer you have to hook up to read trouble codes or not? I'm lost. Its a 95 Maxima Se
loystock
Car: 10 Honda Pilot
97 Infiniti Q45
03 Infiniti Q45
97 Infiniti I30
06 Infiniti M35 Sports
04 G35 & 99 I30-RIP
Take it to Autozone for free diagnostics. Shops/dealerships charges @ $50 for this service. You can also use the on-board diagnostic feature of the ECM but unless you have an FSM (Factory Service Manual), it would be difficult to explain online.
Please read the 'stickies' on this forum, particularly the "Maxima/I30/I35 FAQ," for information about trouble codes. Your car is a 4th gen Maxima (1995-1999)
jynjos13coupe
I have a OBD2 scanner does that work or is this an OBD1?
loystock
Car: 10 Honda Pilot
97 Infiniti Q45
03 Infiniti Q45
97 Infiniti I30
04 G35 & 99 I30-RIP
1996 was the official implementation of OBD II but some manufacturers started using it earlier (OBD III spec was released by CARB in 1994). Try to hook up your scanner. If it doesn't work, take it to Autozone. Even AAMCO is offering free diagnostics. But I typically stay away from that chain.
allensteiner
Car: 1995 Nissan Maxima GLE, 2005 Pontiac Bonneville SE
all 95+ nissan maximas are obdII. the port is under the dash, on the left lower side (inside kick panel) inside the passenger foot well.
aside of hooking up a code reader you may pull the codes by turning the screw on the engine computer and observing how many times the check engine light flashes - there will be long and short flashes which will be repeated.
there is a sticker by the screw on the ecu that tells you how to do it but iirc turn it counter clockwise till stops and then clockwise till stops to read codes then repeat to clear them - don't brake that screw, it's fragile!
jynjos13coupe
Thanks!!! You guys been great. I figured it out. Mass air flow sensor
