eh? »
https://forums.nicoclub.com/eh-u12932.html
Mon Apr 24, 2006 10:23 am
The price for this swap is not cheap. Pricewise, it's probably equivalent to an SR swap. To give you an idea of what it would cost you to do the entire swap here is what I have spent so far:
1999 LS1 w/ T-56 transmission: $3700 shipped- the engine came with a pair of longtube headers that I knew had no chance of fitting so I sold those for $300.
RPM2 232/236 cam: $125 used off E-bayHardened pushrods: $90 brand new off E-bay2005 GTO Oil pan w/ windage tray and pickup tube: $150 shipped
2005 GTO oil pan gasket: $50
1999 Corvette fuel filter (all LS1's, with the exception of the '97 Vette used a returnless fuel system, meaning there is no fuel return line on the fuel rail. The cheapest way to get around this is to use the '99 Corvette fuel filter which has a built in fuel pressure regulator and return line) : $50
Engine mounts: ??? (maybe ~$300-$600 whatever is on the market) I'm making my own so my cost is not relevant to you unless you have the capabilities to make your own.
Headers: This is still in question. Probably custom. I'm going to try LS2 headers as a last resort since GM truck manifolds, C5 Corvette manifolds and F-body manifolds do not fit: Price (anywhere between $100-$600 for manifolds, cheaper if OEM ones will fit, expensive if you can not make your own)
Custom driveshaft: $200-$300
Total Cost: expect EASILY ~$4300+ total without labor unless you have a hookup on the engine/transmission and labor. Mine will probably come in around $4100 because I'm doing my own fabrication and labor.
Then add in the cost of tuning for needed parts: $200-$500. But this is a cost that will be required for either engine (SR, KA-T, RB, or LS1) so that can't be counted.
Horsepower expected with my mods: Probably ~370 rwhp, add an LS6 intake manifold: ~390 rwhp. You could probably get about the same horsepower out of an SR or KA-T but I would imagine the cost would be at least $500-$1000 more (upgraded turbo, fuel injectors at least) (I had a KA-T before and I did all the fabrication on that build (exhaust manifold, intercooler piping, downpipe, 3" exhaust) and I still had ~$3200 into it after purchasing a low mileage KA (27,000 miles), tuned ECU, clutch, etc. and that got me ~270rwhp)
The LS1 will be barely breaking a sweat at 350-400 rwhp and I'd feel much more comfortable beating on it than I did my KA-T.
So bottomline: I feel that you will NOT save any money doing this swap over an SR or KA-T. (Total cost between $4000-$5000+ depending on your level of fabrication skills, the high end being having to pay someone to do it all for you.)
However, I believe the power potential on PUMP GAS and daily drivability (such as startability, idle quality, and reliability) will be far superior to my KA-T.
I know some people will disagree and that's fine, but I've had my experience with the KA-T and I feel for my driving and power delivery preferences the LS1 is a good choice for my S14. Though I wouldn't mind getting a second car and doing an RB swap..I still love turbo vehicles but I want more low end grunt. I think that the RB could deliver that and it would be a fun car.
