REaaaally need help with antenna removal
Mixmastamunkh
Car: nissan 240sx
so i got a new euro antenna from AntennaX.com. the actual antenna i got is pretty nice. it's small and rubber. kind of like an s2000. anyways. i can't get the freaking stock antenna off!!!! does anyone know how to take the thing off??!?? please help me with removing this thing.
Red coupe
Car: 92 Nissan 240sx Coupe
look at the top of the black nub that sticks outa the car. The top is a ring with 2 small holes, put a narrow pair of needle nose plyers into these holes and unscrew it, turn the radio on and it will pop the antenna out. look behind the trunk lining for the motor an the plug for the antenna
Dattebayo
It really doesnt matter, your S13 antenna system will suck anyways...
Mixmastamunkh
Car: nissan 240sx
but the aesthetic pleasure can at least be better, no?
Dattebayo
No! You must suffer eternally for having an old car!The car gods demand it!
240marcuSX
Car: E34 525i
E46 M3
im removing mine too, im prepared to hacksaw it off if necessary, im just going to plug the hole, who listens to the radio anyway?
amolao
Car: 1989 Hatchback (the first one...) w/ Autech sr20de S15
I also replaced the one on my hatch and really had to force the little two hole cap to get it to turn. After many years it tends to accumulate a lot of dirt and/or corrosion....try to spray it with WD40 or something and be prepared to replaced the antenna mount if ends up damaged....I did the same to my other 240 (1991) and the piece came off really easy....who knows???
Mixmastamunkh
Car: nissan 240sx
damn car gods are really given my a hard time with this anetenna. i want to take the whole unit out from the side panel of my car, but it's innaccesesble. i don't need it because i have satelite radio, but i want a cool looking antenna anyways. so this is pissing me off. do i have to take the whole rear fender off??
biggie
You should be able to get to the motor from the trunk. You probably need to remove the plastic pieces from that area. The motor is in front of where the OEM scissors jack is.
amolao
Mustha, take the panel on rear drivers side of the car......this is the only way you can take the assy off. If your new antenna is the complete assy then you need to take the complete old assy. If you got a new "just antenna piece" then you can use the old antenna assy and screw from the top....if design to fit the nissan mount......
biggie
That could be the problem if you have an electric antenna and you have bought one to replace a manual one. The manual mount would be missing, no way to screw it on.
skydragoness
Car: 03' 350z Touring 6spd
92' 240sx 60k survivor :)
Anyone think snap-ring pliers would fit perfectly in those two little holes to get the mast out? I want to replace my broken power antenna with a nice shorter, manual one that i can push down (instead of going through the trouble of removing it and fiberglassing the hole)
bcar240
Car: 1993 240SX HB
My antenna stopped working after it was iced up all winter. I had some free time so I was working on it a few weeks ago, and all I can say is that after I was barely even able to touch the assembly, I just gave up and put the trunk back together. Radio still sounds normal, even with no extension, so it is not very high on my fix-it list.Actually, I got the motor out of my old 240 with only removing the trunk trim, I wished I remembered how I did that (was a while back.)
amolao
I bought the little ebay black one to replace my OEM, works , looks good and it will fit the OEM mount...Is cheap too$$$$... I bought the inside element to fix my power antenna on my other 240 and it does works but it was costly $$$$
amolao
skydragoness wrote:Anyone think snap-ring pliers would fit perfectly in those two little holes to get the mast out? I want to replace my broken power antenna with a nice shorter, manual one that i can push down (instead of going through the trouble of removing it and fiberglassing the hole)
Yes , a needle nose will also work, but if you force it, you will need a new antenna mount......
