jmac »
https://forums.nicoclub.com/jmac-u3614.html
Tue Sep 23, 2003 10:45 am
i have a problem with my 89 pathfinder's transmission. vg30i, re4ro1a, 4wd. it was slipping in all gears for a couple days, then it lost all bite and would not move at all. so, instead of mortgaging my house (these transmissions are not cheap) to have it rebuilt, i decided to do it myself. there were some shavings stuck to the magnet, but appeared to be from the rivets in the band, no other hard parts were worn. i bought a master rebuild kit, with the tech manual, and replaced all the o-rings, drive and driven plates (steel and steel/fiber rings that make up the clutch packs) , gaskets, ball bearings in the valve body, everything by the book. or so i thought. after i got it back together and put it in, filled it with fluid, ran it at idle until the fluid level was perfect, i got in, shifted into reverse, eased on the gas, and was moving! only i was going forward. all gears move the vehicle forward. it would move in park if it wasn't for the parking gear. after checking the troubleshooting part of the manual, and doing the first and second most obvious culprits, the fluid level and the control linkage, the third and fourth choices were disheartening. the forward one way clutch and the reverse clutch are three and four. i don't want to have to take the thing out again, but it looks like i might have to. does anyone here have any ideas before i do? i did not replace the shift solenoids (three of them), the lock up solenoid (one) or the the other one that i can't remember the name of right now. and i didn't replace them because it was shifting fine before i tore it down. and i don't think that the two clutches in question could be put in wrong and still have everything go back in correctly. please help. if i left anything out that might help please let me know.thanks,john
