Re-wire fog lamps
SilviaS14KA24DE
Car: Doriftu
I have a '95 SE with OEM stock fog lamps. I want the fog lamps to be manually turned on, so i can use the fogs with just parking lights. Does anyone know how?
oh and a nice electrial schematic of the lighting system would be great also, if avail. :pface
eddiec
Car: 91 S13
i had this on my frontier for a while.
well i dont have a schematic but here goes. find the wire under the hood for the parking lights. splice into it. run this new wire into the cabin and wire it to your switch. from th other end of the switch run to your fogs. switch on will run parking and fog. switch off is parking only.
if you want to run fogs only, you'll need a 3-way switch and a 12v supply. for that tap into the fuse block. same as before only wire in the constant source on the 3rd pole of your switch.
only thing to remember is to disconect the battery before starting.
SilviaS14KA24DE
Car: Doriftu
how would i go about finding the fog light switch wire? under the steering wheel column?
just a note. my fog switch is on the signal switch. jtlyk
eddiec
Car: 91 S13
could trace it back from the light it self. it for sure has a distinctive color pattern to identify it, but i dont know. i see you have a s14, if it was a 13 i could look in the fsm and look it up. but i dont have a s14 fsm.
SilviaS14KA24DE
Car: Doriftu
where would the line for the parking lights be approx. the wires are confusing under there. is it near the fuse box? anyone with a 95 240 FSM that can help?
SoCalS14
Car: My car...duh
I just got my S14 FSM...Where would I look in it?
SilviaS14KA24DE
Car: Doriftu
oo thanks! uhm under foglights, lighting, lighting wires. stuff like that
SoCalS14
Car: My car...duh
here are the instructions...
SoCalS14
Car: My car...duh
You know, I suck at scanning...I can never get a clear picture when i resize...
SoCalS14
Car: My car...duh
Email me, and I will attach them in a reply...
