re-using pistons?
wild_maxx
Car: 90 TT pearl yellow z32
i have a set of supertech pistons in my current running motor. can i re-use the wrist pins? or should i get a new set? and any recomendations on new type of rings to use?
WDRacing
There are tolerances for play in all the bearings/bushing and the like, have them measured. Depending on how long they were used, I'm willing to bet they'll be fine.
WD
Chezedik
Car: 1991 Nissan 240sx
I second, if you are in specs, great. But we cannot answer that from across the internet. Only your engine builder will know for sure...
wild_maxx
they have about 1500 miles on them. i was an idiot and kept the stock rods so now i have to disassemble the entire engine and add a set of good rods before i destroy the entire engine.
WDRacing
1500 is nothing...you'll be fine. Just inspect them for visual wear, if non is noted then you're all good.
wild_maxx
thanx for the info WD
koukiKA240
Car: 1991 240sx KA-T
i had 7k on my motor and spun a bearing, i went in with the same wrist pins and locks and just replaced the rings. So far i only have 40 miles on the motor but they should hold up fine.~Sam
wild_maxx
what kind of rings did you go with?
Chezedik
What is wrong with stock rods? Or are you pushing too much power for them. Otherwise, there is nothing wrong with re-using them either. Unless of course they are bent.
WDRacing
The stock rods have been snapping under somewhat light loads. Around 350ft lbs in some cars.
koukiKA240
wiseco was the only company i found that would sell me a set of rings. Came out to just over $100~Sam
Chezedik
Light loads?!?!? WD you have had way too much boost for that to be considered light. I would kill for that. But good for you (it's not like I'm jealous or anything, whatever!). No, I mean it.
wild_maxx
I would rather spend the extra cash on a good set or rods, rather than building a completely new motor. Plus i can up the BOOST when i feel the need to.
