re-using head bolts?
sunnys14
Car: S14
hey guys, i was just wondering if its ok to reuse head bolts? my friends boss said that the tend to elongate over time? am i supposed 2 torque it a lil more? any input would be appreciated, thanks
Nismo_Freak
Car: 89 Nissan 240SX
You have to measure them for stretch, it's all outlined in the FSM.
I don't suggest it even if they are in spec. The metal has been fatigued once.
spider_slayer
Car: S14 240SX
S13 240SX
arp bolts are only like 100 bucks. its comptetly worth it for the reasons that nismo stated.
ericherm1
Car: 1997 Pickup XE 2.4L 4x4 Single cab short box
1991 BNR32 Skyline GTR
1991 240sx SE SR20DET + S13 Silvia Front end swap (Sold)
I bought the ARP bolts and they dont fit......too short
nismostate
Car: all sorts of motorsports
don't recommend reusing it. most fsm says not to reuse oem head bolts. get ARP. where did you get your bolts from ericherm1? never heard of this problem before.
ericherm1
I got them from http://www.9secondracing.com. The # on the box is:
ARP202-5402NISSAN SR20DET MSK*
Is this the right kit?
If so could someone fill me in in how to use a 6" head bolt on a 8" head.
NY S13 SR
Reusing them is fine for SR20's. Compare them to each other, if they are all the same none longer they are usually fine. You can reuse them multiple times if they are not stretched. ARP studs are good but harder to work with.
________________Jeff Hhttp://www.heavythrottle.com
ericherm1
ericherm1 wrote:I got them from http://www.9secondracing.com. The # on the box is:
Ok, I just got off the phone with ARP and they told me that the company that I bought these from sent me the wrong kit. The kit they sent me is a Main Stud Kit.
The proper kit for the Head Studs is:
ARP102-4701NISSANSR20DET HSK*
Hope this helps other people!!
