re use of tpm
Discussion of Infiniti's amazing (and underrated) sport-luxury crossovers, the EX35 and EX37. For 2014, the EX series will be renamed QX50, in line with Ininfiit's new naming conventions.
OneOfOne
I have a chance to get a tech pkg 2010 ex. if I go to 18s will I be able to re use the original tpm?
txgcoupe
Car: 2007 G35 Coupe/ 2010 EX35
Get a part number for both from the dealer.
John
jmess
The sensors are the same for 17s or 18s so you can use them.
OneOfOne
thanks for the answers but they dont address the question. CAN I RE-USE THEM FOR THE NEW WHEELS?
jmess
You didn't say aftermarket so what was the question :-)
There are some wheel designs that don't like sensors and you have to band or glue the factory sensors and use standard valve stems. The sensors don't care if the wheels are factory or aftermarket but do care if the wheel design (valve stem location) is compatible with common sensors. I would guess 80-90% of the wheels on the market now are ok with sensors.
Return to “Infiniti EX35 / EX37 and QX50 / QX55 Forum”
