Found the instructions on the G35/G37 forum to reset the ECU. Mine needed to forget how the old fart that used to own this drove it and start learning that I like to give it a little gas. Well I just did this last night and drove it a bit and the AT does feel better under hard acceleration. Very happy I tried it. Only took 5 times to get it!
Here are the instructions copied from that post:
"Read the process a few times before you try to do this its ALL ABOUT TIMING:
1) With the key in your pocket/car, push the Engine Start button TWICE (so the car is fully on, but not started)
2) Within three seconds of the car "ON" (again NOT started), Floor (all the way down) and Release the gas pedal fully 5 times within 5 seconds. Do not do this too fast.. 1..2..3..4..5
3) Wait 7 seconds then floor the gas pedal and hold for 10 seconds. After that 10 seconds the Check Engine Light will start to blink slowly.
4) Release the pedal and floor it down once again and hold for 10 seconds. After these 10 seconds the check engine light will disappear then begin to flash much more rapidly. After you have done the following turn the car off and then back on. The ECU is now reset!!
Again, this reset is all about timing, if it does not work for you, try try again until it does!
My suggestion on getting the timing down is have a CD or ipod playing (no sound) and use that clock to count.
