Ok guys I'm having an issue with starting my skyline i initially replaced the steering rack which took me white a while and the motor was raised from front for about 4mths. After o replaced the rack started it up and checked it all good after which the fuel ran out. Had to leave it like this for about 2wks.
Today I got some fuel and put it in tried starting after disabling the immobilizer and to my shock the car doesn't crank over when I switch it to start the exhaust temp lights comes on and it doesn't even crank over.
The lights don't dim when starting neither do interior lights. It's like the immobilizer is sticking. Bit if that was the case the dash lights wouldn't light up.
Any guys been through this similar scenario. If I make any progress will update but I'm stuck at mo cause no clue as to why it's doing this.
