re-programming keyless entry fob for 00 frontier
blues14
Car: 1995 Nissan 240SX GTS-t
I just got a keyless entry 'clicker'/fob off ebay and need to re- program it so it will work for my 00 nissan frontier. how do i do it, or do i need to take it in?
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
To reprogram (enter new ID) key fob (keyless remote controller) follow the steps.
1. Close all doors and lock all doors
2. Insert and remove the key from the ignition key cylinder more than six times within 10 seconds. (The hazard warning lamp will then flash.) NOTE: Key should be withdrawn from ignition key cylinder completely each time.
NOTE: Do not rush the insertion/removal key cycling process. The side marker/tail/license lamps and interior illumination will flash twice when this step is accurately completed.
3. Insert key on ignition key cylinder and turn ignition key switch to "AAC" position At this time, the new ID code is entered and original (previous) ID codes are erase.
4. Press any button on the new remote controller once. (The hazard warning lamp will then flash)
NOTE: Do not press the button more than one time in the above step. If the button is pressed more than one time, the programming procedure will not be successful. The side marker/tail/license lamps and interior illumination will flash twice when this step is accurately completed and programming is successful.
If there is only one remote controller skip step 5.
5. Additional ID code entry Release the door lock, then lock again with door lock/unlock switch (In power window main switch)
6. Remove key from ignition
7. Unlock driver side door, open driver side door and then close the door. (END)
blues14
what it that does NOT work? Yes, i just put a new battery in it. the gauge lights flash after inserting the key 7 times, but thats all that goes right. can a dealership reprogram these things?
elwesso
2007 BMW M Coupe
I od the same procedure basically on my Q45, and what i would recommend doing is inserting the key in and out as many times as possible in roughly 10 seconds.
93Miata
Car: 99 I30
Sure you got the correct remote? They're usually listed wrong on ebay.
All I needed was to add remotes to my receiver. I got new units for about 1/3 dealer price for my 99 I30 & 94 J30 on -
http://www.ThePartsYouNeed.com
They seem to have remotes & instructions for everything on their site.
