Yeah. I had the same experience the few times I used the older Continental DWS and the original Pilot Sport A/S ... around 20 to 25k miles (probably changed at the 22k to 23k mark). Mostly highway driving.EniGmA1987 wrote:30K miles seems pretty good for any kind of performance tires, especially DWS. Both myself and another guy I know were replacing DWS tires every 20K miles because they just wear out so quick.
I actually got like 35-40k out of my last set of DWS. I had them on my 07 for like 10k and then I had them on my 2011 for another 25k or so. I rotated them every 5k or 10k. Kept pressure at like 38psi. Still had some meat on em (maybe another 2-3k) but the rim was bent so it threw off the balance and the tire started to wear unevenly so I bit the bullet and switched to my 20's earlier than I thought I would.szh wrote:Yeah. I had the same experience the few times I used the older Continental DWS and the original Pilot Sport A/S ... around 20 to 25k miles (probably changed at the 22k to 23k mark). Mostly highway driving.EniGmA1987 wrote:30K miles seems pretty good for any kind of performance tires, especially DWS. Both myself and another guy I know were replacing DWS tires every 20K miles because they just wear out so quick.
Z
Yeah, I think they were able to increase the longevity in later generations of the DWS - my experience was with the first set of Continental DWS when they came out. I tried them after switching from a set of Michelin Pilot Sport A/S (also early versions).IlyaKol wrote:I actually got like 35-40k out of my last set of DWS. I had them on my 07 for like 10k and then I had them on my 2011 for another 25k or so. I rotated them every 5k or 10k. Kept pressure at like 38psi. Still had some meat on em (maybe another 2-3k) but the rim was bent so it threw off the balance and the tire started to wear unevenly so I bit the bullet and switched to my 20's earlier than I thought I would.
Good tires, yes!ericthered wrote:I've been totally happy with my Michelin Pilot Sport A/S 3 (W rated) chosen for their wet traction.
Yes, indeed. The high load index generally means a stronger tire including the side-wall, etc. The belts do not get stressed as much, and less likely to fray or break inside due to miles ...ericthered wrote:I looked on tire rack, the new Pirelli (like the Michelin) are load range 100, a very good thing - in my experience higher load ranges translate to longer lasting belts on tires that are pushed.
Exactly! My reasons for staying with the Pilot Super Sports I now have, even though the price can be higher than other tires ...Larz wrote:Michelins (for me) handled just as well at the end of the tread life as they did when new.
Hey Larz, been a while for me herein. I retired about 2 yrs ago, bought myself a new '13 RoadTrek 190 P and have been tooling around in it, vs the nowhere to sleep, brew my morning cup of java and nowhere to peeLarz wrote:Hello Mr Antz! So glad you are pleased with the Pirelli's. I remember you had quite a time with tramling in the past, so it must feel great to know that after dropping some money, you didn't take a step back. As for the squealing, slow it up, mate! LOL Seriously, though, the difference in the tread compound, sidewall stiffness, and tread design between ultra high performance and grand touring tires will likely be noticeable depending how you drive. It's a different type of tire and according to the 'experts', the ride should be more on the comfort side than the sport side.
I'm still quite happy with my second set of Ventus S1noble2's, but they barely have 8,000 miles so the real test will come after at least 5,000 more miles.
Please let us know how these Pirelli's work in the snow. They are standard on Jaguars, so I would expect they do well in all conditions.
See, this is why I don't bother with Consumer Reports. First of all, I agree that all three of these brands are just fine. However, none of them are classified by the manufacturer as 'performance'. These are basically "touring" tires. Nothing at all wrong with touring tires, they are just a different class and don't provide performance handling - they are designed for comfort and not spirited cornering, etc. The sidewalls are less stiff (for comfort) and they have less grip (less noise) than performance tires.DS2009m35x wrote:Latest article from Consumers Report:
Performance All-Season Tires
There is a three-way tie for top score between the Continental PureContact, Michelin Premier A/S, and the Pirelli Cinturato P7 All Season Plus. Continental gets to the top of the heap for its strong performance in dry and wet grip, handling, snow traction and a quiet, comfortable ride. Both the Michelin and Pirelli models share many of the same qualities, along with longer tread life. Performance all-season tires come on many newer cars with speed ratings of H (130) and V (149) mph.
Note that I had the Pirelli P7s installed on my M35x last year. Dealer reported at last month's oil change (special: 2 for $39) that all tires had 10 tread depth. I have approx 12k on the tires. For all season tires, I was pleased with traction the few days I drove in snow last winter.
